Discussion topic: My sky Q installed yesterda
This message was authored by: Super+Sa
My sky Q installed yesterday won't download and can't watch on catch up???
Re: My sky Q installed yesterda
@Super+Sa Sky signature comes with live TV, catchup and boxsets.in SD as standard you may be trying to download the programme in HD
The default download setting is HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
If you have the HD pack or you still get the same message after trying to download in SD et us know and we can escalate this to Sky for you
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
