Discussion topic: My sky Q box won’t work
Message posted on 04 Aug 2023 07:31 PM
Hi, my sky Q box has suddenly stopped working the light is orange & remote is working but when I try to turn sky on it won't happen. My screen says check device power but it's Connected properly.
Message posted on 04 Aug 2023 07:41 PM
Re: My sky Q box won’t work
Hi @984B
Looks like the message is coming from your TV set and not the Q box.
Check all your TVset connections and reboot your TV set.
Disconnect the power to your TV set and then reconnect it after 30 seconds.
