Discussion topic: My sky Q box won't record anything - always says download failede
This message was authored by: Helen365
My sky q box won't record anything. I have reset the harddrive, I have checked and updated the software, and I have had a new box delivered (set up today). Still can't record anything from on demand/box sets. It will record a program I am watching, but nothing else.
Re: My sky Q box won't record anything - always says download failede
@Helen365
Are you trying to download something in HD without having the HD add-on?
Hi @Helen365
Avatar for Helen365
Hi everyone, thanks for the replies.
OH came home and figured out the raspberry pi-hole thing was blocking sky downloads. Problem solved!
