Discussion topic: The dish box is not working, the lights are on but not turning green and connecting to tv
Message posted on 27 Aug 2024 05:50 PM
Message posted on 27 Aug 2024 05:58 PM
Re: The dish box is not working, the lights are on but not turning green and connecting to tv
Hi @Amandip
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
