Discussion topic: My sky Q box is on with a green light but no signal to tv. I have checked connections.
This message was authored by: Sjc1
Any one had this issue?
Re: My sky Q box is on with a green light but no signal to tv. I have checked connections.
Hi @Sjc1
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
This message was authored by: loverboi
@Sjc1 have you tried another hdmi and you checked that your on the right source on tv?
This message was authored by: Jimbob16
Im experiencing this, however the steps recommended haven't worked in this instance.  It says it's got a signal coming from 2 HDMI port on the TV, but there's no picture, just a black screen.
Try restarting the Q at the wall. Or the "home 1080 home" resolution change on the remote.
