2
This discussion topic has been answered Discussion topic: My second box won't connect error code MR004
This message was authored by: Justme75
My second box won't connect it's giving me error code MR004
Re: My second box won't connect error code MR004
Hi @Justme75
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
@Justme75 Have you tried rebooting your main Q box ie
then
reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Justme75
Answered - Go to Answer
