Discussion topic: My second box is not working properly
This message was authored by: Shar3
My second box keeps freezing.we have done all the normal things like turn it off reset it and also done a update.we have got a new remote because we thought it was that but it is still doing the same thing.?it can work for about 1-2 hours then when you want to turn over channels it stops working again and freezes up.
Re: My second box is not working properly
Hi @Shar3
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
