Discussion topic: My remote is not operating when pressing the enter button
This message was authored by: Matrix971
The problem concerns my mini box
My enter button is not responding when trying to respond to connecting to my WiFi
other functions such as volume control is ok.
l am constantly having to reconnect my mini box to my WiFi.
This message was authored by: Mr+Flibbles+86
Re: My remote is not operating when pressing the enter button
Posted by a Sky employee
Hi there @Matrix971, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Hi @Matrix971 Try :-
Re-pair your remote
Hold down 7 and 9 until the remote's light flashes 4 times to factory reset your remote.
Then you need to pair it again:
Hold down 1 and 3 together
Select Continue and follow th on screen instructions.
Then reboot your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, followed by any Mini boxes?
This message was authored by: Addie15
Update-We are closing this invite now due to no response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
This message was authored by: Warwick5
Sky q my enter button not working
pressed 7    9
then 1.    3.  Paired
screen ready to control tv but to continue you have to press ENTER this button not working any ideas ?? Please
