Discussion topic: My multi screen mini box keeps on glitching and stuttering
This message was authored by: Stephen82
Re: My multi screen mini box keeps on glitching and stuttering
@Stephen82 Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Stephen82
Try a Network Reset on the mini.
This message was authored by: Traps7
You're assuming he's on wifi. One of mine does it too & mine are hard wired.
This message was authored by: Petitiin
I have the same issue and mine is hard wired reset has not helped
This message was authored by: 1978nick
Hi
Has anybody got a solution? Sky Q and Sy mini boxes are hardwired. All firmware up to date on sky boxes and router etc.  reset and rebooted entire system.
Sky Q mini box stutters when watching live TV or a recording. The Apps (Netflix for example) on the Sky Q mini work fine.
Nick
This message was authored by: Allan274
Did you get an answer for this? We're experiencing the same problem on hardwired boxes.
I'd forgotten all about this problem. Mine seems to have fixed itself as I haven't had the problem for months now.
Sorry I can't be of more help.
