Discussion topic: My multi room sky box is not working
This message was authored by: 9320
The main Sky Q box is working but the box in the kitchen does not work despite rebooting a few times
Re: My multi room sky box is not working
In what way 'not working'?
Have you tried power cycling the main box too?
@9320
Are you seeing any error messages on the screen the mini box is affiliated to? Have you tried rebooting the main box then doing to mini box?
~ press the 🏠 button
