Discussion topic: My mini boxes aren’t connecting
Message posted on 25 Feb 2024 03:03 PM
My 2 sky mini boxes aren't connecting to my main sky q box.
the sky q box is working fine.
ive tried everything!
Message posted on 25 Feb 2024 03:35 PM
Re: My mini boxes aren’t connecting
Hi. Same issue (almost)
Set up mini with no problem but had to unplug to move slightly (cable is really to short!).
However, I get the part where it states press home button when screen is blank but I just get a no signal and to check cables etc - just the orange light. I've tried
Checked source. Hdmi ok.
Hdmi cec player not connected? Turned off in case
Remote removal batteries/reset
Unplugged all cables, inc tv and left for a bit
Reconnected everything.
Have no idea what to try next as I don't think it's to do with the main box as I'm not getting that far.
Hopefully someone can answer both!?
Message posted on 25 Feb 2024 03:58 PM - last edited: 25 Feb 2024 04:01 PM
Hi @Baggybrett
Reboot the mini as above. Start with the mini nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
