Discussion topic: My mini box will not work
Message posted on 07 Jul 2023 08:35 PM
Just re plugged my mini box in and will not work
Message posted on 07 Jul 2023 08:53 PM
Re: My mini box will not work
Hi @Paul+DB
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
