Discussion topic: Location check failed
This message was authored by: Marks5882
I can't download any movies as it says location check failed. I had the same with Disney plus but they fixed after a call. Any ideas?
Re: Location check failed
@Marks5882
If you use a computer or WiFi device to go to any 'where is my IP' type website, where does that say you are located?
Avatar for Marks5882
Says Slough.
This message was authored by: slimpo57
https://helpforum.sky.com/t5/Sky-Q/Geo-Location-Servers-Anyone-had-having-issues-with-SkyQ/td-p/4341...
I had the same issue. Sky GeoLocation Servers said I was in Sweden but other sites were fine. Issue was eventually fixed after someone on here raised it to a Sky employee who knew what they were doing (not a front line phone agent following a script - no disrespect meant!!)
