Discussion topic: My mini box will not turn on
Message posted on 19 Sep 2024 06:54 PM
I have a small box it won't turn on it flashes then goes off won't come on .
Message posted on 19 Sep 2024 07:16 PM
Re: My mini box will not turn on
Hi @Ethan2006
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing this
Work through the following link Some of it does relate to minis.
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
