Discussion topic: My mini box is not working
This message was authored by: StuartD2
I have had problems with my Sky Q mini box on and off for the last few years. I have previously contacted Sky about it so there should be some reference to it on my account. It is now not working at all and says it can't connect to my main Sky Q box.  I have tried everything, switching the minibox off and on and going through the usual steps to try and re-connect. I have also switched my main Sky Q box off and on and gone through the usual steps to try and connect the minibox and nothing is working. It comes up with errors MR104 and MR109. I think I need a new Sky Q minibox.
Re: My mini box is not working
Hi @StuartD2
Not knowing what you consider as usual steps have you completed the following exactly as listed.
Reboot the mini as above.
Just for information.
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Avatar for StuartD2
Hi, thanks very much for getting back to me I really appreciate it. Yes I've tried all those things and still having issues so I'll contact Sky and see what they say...
