Discussion topic: My mini box is not operating any suggestions
Message posted on 31 May 2024 05:49 PM
Message posted on 31 May 2024 09:37 PM
Re: My mini box is not operating any suggestions
@Vin7 Have you tried rebooting your main Q box ie
then
rebooting the mini box
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Message posted on 31 May 2024 10:30 PM
Hi @Vin7
If the mini has an Amber led on the right side
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
