Discussion topic: My main box isn’t working
Message posted on 27 Oct 2023 06:37 PM
My main sky box isn't working ! Recordings wouldn't play and now it won't come on at all
Message posted on 27 Oct 2023 06:40 PM
Re: My main box isn’t working
Hi @Finbar3030
Have you tried rebooting your Q box?
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 07 Jan 2025 02:22 PM
The box is dead, no lights electric nothing just a black box
Message posted on 07 Jan 2025 02:24 PM
Have you tried another electrical device in that plug socket or tried plugging the Sky Q box into another socket?
Message posted on 07 Jan 2025 02:34 PM
Yes I have put it 3 different sockets, unplugged the back for about 3 mins. Nothing
Message posted on 07 Jan 2025 02:37 PM
Hi @Fals1 Sounds like it is time to contact Sky.
Message posted on 07 Jan 2025 02:51 PM
You need to call Sky. They may arrange a replacement main Sky Q box to be sent out by courier. If they do the courier driver will expect the faulty box to be disconnected and ready to be swapped on your doorstep. In this case also remember to remove your viewing card from the faulty box.
Message posted on 07 Jan 2025 03:52 PM
Yes, I have contacted Sky and they are sending a new box. Thanks
