Discussion topic: My homepage where the aaps are on sky q have disappeared
Message posted on 04 Feb 2024 10:44 AM
My sky Q apps have disappeared everytime I press the home button it takes me to the scarts
Message posted on 04 Feb 2024 10:55 AM
Re: My homepage where the aaps are on sky q have disappeared
Hi @Saeed
Assume you have tried rebooting your Q box
Message posted on 04 Feb 2024 12:10 PM
I will give it a go but I've kind of tried everything
Message posted on 04 Feb 2024 12:25 PM
That has worked but now my remote isn't working I've tried pressing 1-3 together it says its connected but I can't change the channel only the volume button and on/off button works
Message posted on 04 Feb 2024 12:27 PM
@Saeed Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Saeed
Try completly resetting your Bluetooth remote.
Message posted on 04 Feb 2024 12:37 PM
For my tv channels it showing none of them are unavailable so my chanels hav disappeared also I tried all the following for my remote which is working fine now but I hav no channels left which us bizarre the aap are showing but are blank
Message posted on 04 Feb 2024 12:44 PM
