Discussion topic: My connection cable is damaged and I need a replacement
This message was authored by: Theresa8
Message posted on 15 Jun 2024 07:07 PM
The cable which powers the sky box is damaged. The sky box does not turn on.
Find out more
Message posted on 15 Jun 2024 07:18 PM - last edited: 15 Jun 2024 07:19 PM
Re: My connection cable is damaged and I need a replacement
Hi @Theresa8
If it is the normal power lead with figure of eight connection plug to the Q box then these are readily available from Online or High street stores. If it is mechanical damage then Sky are under no obligation to replace it.
