Discussion topic: My box won’t turn on
This message was authored by: Jezza990
My main box won't turn on, I've done the update and it still won't turn on and I have followed the instructions on line and it saying I need a new box
Re: My box won’t turn on
Hi @Jezza990
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Jezza990
Didn't work, sky are sending me out a new box! I've had it more than 5 years I think - just think it werid how it's just stopped working. When I get my new main box do I send this box back to sky?
