Discussion topic: My TV is stuck on the wrong source. There is no signal because it is on Ext. I can’t move it to HDMI
Message posted on 29 May 2023 08:52 PM
There is no signal as the source is on Ext. when I press the arrow button on the SKy remote to move the source to HDMI nothing happens.
Message posted on 29 May 2023 08:59 PM
Re: My TV is stuck on the wrong source. There is no signal because it is on Ext. I can’t move it to
@Louise+Woki Have you thought to use the TV's actual remote rather than the Sky remote??
Hi @Louise+Woki
Is your Q remote correctly paired to your TV?
Have you tried using the TV remote:
Message posted on 29 May 2023 09:31 PM
@Louise+WokiAs well as using your TV's controller depending on your TV you may be able to turn off all inputs except the ones you are using, I can on mine it is a Toshiba.
