Discussion topic: My TV is not recording properly.
This message was authored by: Smith_a15
My Sky TV is not recording properly. The recordings mute, freeze and i cannot get this to stop.
Re: My TV is not recording properly.
@Smith_a15 Have you tried rebooting your main Q box ie
if that doesnt work
then
You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
