7
This discussion topic has been answered Discussion topic: My Sky TV guide is only showing HD programmes and not the regular TV programmes I want to watch?
This message was authored by: Jan_Cos
I cannot seem to be able to dispaly the 'normal' TV listings on my Sky Q ?All I can get are the HD listings which don't correspond with my paper TV guide? Can you help?
Re: My Sky TV guide is only showing HD programmes and not the regular TV programmes I want to watch?
@Jan_Cos wrote:
@oldfella I should add that the HD programmes currently showing on my TV are all yesterday's listings.
Hi @Jan_Cos
Hi @Jan_Cos
Try rebooting your Q box.
The HD channels have the same schedule as the SD versions. Perhaps there have been schedule changes since the paper TV guide was printed.
Avatar for Jan_Cos
All the channels are completely different? I was watching the rugby on Amazon Prime and have only had this issue since then. My Sky Q is showing as being on HDMI 3 but I'm not sure if it should be and I can't seem to change it? Not sure if that is what is causing the issue?
Avatar for Jan_Cos
I have tried rebooting as suggested twice, but nothing has changed.
Avatar for Jan_Cos
Hi @Jan_Cos
Avatar for Jan_Cos
@oldfella @Thank you very much. All good!
