Discussion topic: My Sky Q has TV has been freezing. I get a message on the mini q box saying the signal network.
Message posted on 21 Feb 2024 08:01 PM
I unplug the main sky box and reboot. It then happens again. We have to the box off at least three times. Sometimes it works but then won't turn channel.
Message posted on 21 Feb 2024 08:02 PM
Re: My Sky Q has TV has been freezing. I get a message on the mini q box saying the signal network.
Hi @Mark173
Try resetting the Network connection.
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Message posted on 21 Feb 2024 08:20 PM
Thanks for your help. I've done as you've explained. We'll see if it does it again.
Message posted on 23 Feb 2024 07:35 PM
Looks like I'm back to resetting again. How do I get an engineer out to check everything?
