Discussion topic: My Sky Q box won’t show a picture on my main TV. The box is on but it doesn’t seem to connect to TV
Message posted on 09 Apr 2024 06:15 PM
I've checked the TV including Wi-Fi and box connections.
The mini box is working and I can watch Sky channels on the Internet TV connected to that box
I have a separate amp connected. When I turn on the system the TV comes on first followed by the amp and then the Sky box. It still comes on but nothing shows on the screen
The TV works and I can view Aps such as IPlayer
I've checked everything I can on screen and the internet and Sky box connection are both shown as good
Any advice would be welcome
Message posted on 10 Apr 2024 09:45 AM
Re: My Sky Q box won’t show a picture on my main TV. The box is on but it doesn’t seem to connect t
The mini box is working and I can watch Sky channels on the Internet TV connected to that boxI have a separate amp connected. When I turn on the system the TV comes on first followed by the amp and then the Sky box. It still comes on but nothing shows on the screen
I've checked everything I can on screen and the internet and Sky box connection are both shown as good Any advice would be welcome
Hi @Cins
When it is all switched on and you have a blank screen I assume the Q box is on with green led.
If you switch the Sky Q box into standby with the Q remote do you get a brief second of video and sound on the TV.
If you do try rebooting your Q box.
Message posted on 10 Apr 2024 10:01 AM
It sounds like you've already done some troubleshooting steps, but let's go through some additional suggestions to try and resolve the issue:
1. Check HDMI Connections: Ensure that all HDMI cables connecting your TV, Sky box, and amplifier are securely plugged in. Sometimes a loose connection can cause issues with video output.
2. Check Input Source: Make sure that the input source on your TV is set to the correct HDMI port where your Sky box is connected. Use the TV remote to cycle through the input sources until you find the one that corresponds to the Sky box.
3. Restart Devices: Try restarting all the devices in your setup - the TV, Sky box, and amplifier. Sometimes a simple reboot can resolve technical glitches.
4. Check Sky Box Settings: Access the settings menu on your Sky box and ensure that the video output settings are configured correctly. You may need to adjust the resolution or display settings to match your TV's specifications.
5. Test with Different HDMI Cable/Port: If possible, try using a different HDMI cable or connecting the Sky box to a different HDMI port on your TV. This will help determine if the issue is related to the cable or port.
6. Factory Reset: As a last resort, you could try performing a factory reset on your TV and/or Sky box. Keep in mind that this will erase any customized settings, so proceed with caution and only do this if other troubleshooting steps have failed.
7. Contact Support: If none of the above steps resolve the issue, it's possible that there may be a hardware problem with one of your devices. In this case, contacting the manufacturer's support or seeking assistance from a professional technician may be necessary.
By following these steps, you should be able to narrow down the cause of the issue and hopefully get your Sky box working properly again.
Message posted on 10 Apr 2024 10:14 AM - last edited: 10 Apr 2024 10:17 AM
@Cins wrote:I've checked the TV including Wi-Fi and box connections.
I assume the sky box is not connected to the amp but the tv directly and the correct HDMI input is selected in the tv?
Message posted on 11 Apr 2024 10:02 AM
Thank you so much for this; I had tried rebooting with no success but then I tried chaning the input between HDMI 1 and HDMI4; interstingly that provoked the audio from a sky channel to come throuh albeit without a picture;
I then tried to use the oncreen TV settings to check for picture format; After a lot of to and froing the home screen appeared momentarily - as you describe;
Eventually I was able to get the home screen albeit still with the volume from a channel not shown on screen {it was BBC4}
After that I recovered both sound and picture - but with little understanding of the "fix". It seems to be working normally now.
Message posted on 11 Apr 2024 10:07 AM
Thank you for all the advice; I have resolved the problem but switching between the HDMI input which strangely prompted the relay of audio through the sky box; eventually after much fiddling with the on screen picture settings I recovered that too and its working normally. I had been through all the suggested steps but thank you; a review is always useful.
I think you are right and that it was a configuration issue; I run my multiple remotes through a harmony system which means that you can use a single remote for audio tv sky and my tuner etc; I wonder if the settings got mixed; they sytem can be a little unstable.
I am very grateful both for the interest and advice
Message posted on 15 Oct 2024 11:34 AM
Since Sunday morning, I have not been able to get any service from my q box, the only thing I see is a almost blank screen with a little box in the centre saying No video available, I have checked all the leads and power points also just one small yellow dot on the q box any additional help for me please.
Message posted on 15 Oct 2024 04:27 PM
@jamesgscully28 does the box come on if you press the button that shows the yellow/amber light
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
