Discussion topic: My Sky Q box keeps disconnecting from a third party router
Message posted on 30 Nov 2023 12:28 PM
6 months ago I switched from Sky Broadband to Be Fibre as they offered fibre to the home and speeds of up to 900mbs, which Sky couldn't match in my area. I connected the SkyQ box to the third party router at that time and for 6 months there was absolutely no issue at all.
My broadband contract with Sky did not finish until the beginning of this month so I continued paying it until expiry, even though I was using the third party provider, in order to avoid any penalty. Immediately after the Sky contract ended the Sky box started to disconnect from the third party router on a continuous basis. I keep going through the reset procedure, it connects and then less than one minute later it disconnects. This has been happening now every day since the expiry of my contract . Is Sky deliberately causing the box to disconnect to try and get me back as a broadband customer? I don't know but if Apple can slow down i phones it wouldn't surprise me. But unless I can get a solution to this then I am likely to cancel my TV contract also rather than revert back to Sky broadband. BTW I do not have this problem with any other devices connected to this third party router
Message posted on 30 Nov 2023 12:38 PM
Re: My Sky Q box keeps disconnecting from a third party router
@NJS5 wrote:Is Sky deliberately causing the box to disconnect to try and get me back as a broadband customer?
No.
Are you using any form of mesh network? Disconnecting so quickly is usually related to that.
For a non-Sky ISP you can only use 2.4GHz - it's often a good idea to create 2 SSID's for each band (2.4+5) and ensure any steering is disabled as this could explain the disconnections.
Message posted on 30 Nov 2023 01:26 PM
Thanks for your reply. No, I am not using any other Mesh network. However, just turned on 2.4Ghz hot spots on the Sky Box (was previously off ) but it is still disconnecting
Message posted on 30 Nov 2023 01:32 PM
The hot spots won't help. You need to check the admin config of the BeFibre router.
I would recommend splitting SSID's if possible.
Message posted on 30 Nov 2023 03:11 PM
Not entirely sure how to split the SSIDs on the router but will research it.Thanks. However, doesn't really explain why it worked perfectly for 6 months without any issues.
