5
This discussion topic has been answered Discussion topic: My Sky Q box is not working
This message was authored by: stanley71
Sky Q Box just has orange light and no picture
Re: My Sky Q box is not working
Hi @stanley71
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Hi @stanley71
Avatar for stanley71
Perfect, Oldfella. Simple as that. Thanks so much. Working fine now
This message was authored by: Ttsb11
Yes.
It wont let waych catbup or on demand
My sky box will not let me use on demand or catchup
Can someone help me
