Discussion topic: Multiscreen not switching on
Message posted on 03 May 2025 11:38 AM
Multiscreen not switching to green light, I tried reset etc
Message posted on 03 May 2025 01:25 PM
Re: Multiscreen not switching on
@Satpal wrote:Multiscreen not switching to green light, I tried reset etc
Do you mean you have a Sky Q Mini box that will not turn on?
If you sign into Sky Help here and follow the steps for Q equipment that won't turn on, you should be offered a replacement: https://www.sky.com/help/home/sky-tv/sky-tv-q
Message posted on 03 May 2025 02:43 PM
Hi @Satpal
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the Q box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
