Discussion topic: Sky update software stuck on 1 of 2?
Message posted on 03 May 2025 10:19 AM
Sky software update has been stuck on 1 of 2 and won't move off it
have tried turning it off and on but that hasn't worked
any advice on solving this?
Message posted on 03 May 2025 10:56 AM
							Re: Sky update software stuck on 1 of 2?
Hi @Christian71
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
