Discussion topic: Multiroom
This message was authored by: Rlo197
Multiroom
Sky multiroom isn't working. States no signal on the tv and light is orange on the multiroom box.
Re: Multiroom
Hi @Rlo197
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
