Discussion topic: Multiroom box
This message was authored by: Tinkerbell26
Multiroom box
My multi room box is loading menu but the small screen top left is black and won't play and channel etc. When going into settings it's saying to reactivate. It's connected to Internet and box down stairs is working fine
Re: Multiroom box
Hi @Tinkerbell26
Reboot the mini as above.
