Discussion topic: Multiroom box not working
This message was authored by: liddylee
Sky Q multi room box not working. Have checked the signal and broadband connection these are all connected.
The main Sky box is working fine with no problem.
Re: Multiroom box not working
Hi @liddylee
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for liddylee
Have tried your seggestions and reset manually n box, mini box still not responding could  I request someone else o come out and look at this please
Hi @liddylee
Did you carry out the Network reset on mini?
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
