Discussion topic: Multi screen not working
This message was authored by: Oxo
My multi screed is not working, the main screen is. It is all connected when going through settings but still says no satellite sign on screen
Re: Multi screen not working
Hi @Oxo
Reboot the mini as above.
This message was authored by: KevinBrad1957
The multi room box is not responding and the tv says no signal, I have reset the router but no response, I have checked the main Sky Q box and that is working
