6
This discussion topic has been answered Discussion topic: Multi room
This message was authored by: Alistair29
Multi room
When I try to connect my multi room I get "accessibility on Sky Q dialogue box and it won't let me go to settings or skip and can't get past this page
Please help!
Avatar for Alistair29
This message was authored by: Alistair29 Answer
Re: Multi room
All sorted now thank you 🙏
Re: Multi room
@Alistair29
This Accessibility screen issue comes up every now and again, Sky have previously suggested the following...
  • Unpair their Sky Q remote from the box by holding 4&6
  • Wait for the remote to flash
  • Then dismiss the information screen "Skip & set up later"
  • Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Re: Multi room
Thank you I'll try that when I get home later
Re: Multi room
Hi
neither 4&6  or 7&9 do anything!!!
This message was authored by: Me134
Re: Multi room
@Alistair29 wrote:
Hi
It's "try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV", Pressing 7 & 9 together don't show anything as you've just unpaired the remote and the Sky box. You have to follow it up with 1 & 3 together to pair them up and the find your TV to link that up as well.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Re: Multi room
@Me134 wrote:
@Alistair29 wrote:
Hi
Note the 1 & 3 will only work after managing to dismiss the message
@Alistair29  Note - You must press & hold the buttons together until the red lead above the SKY logo button blinks 4 times
Re: Multi room
