Discussion topic: Multi room
This message was authored by: Lovelocked
Multi room
Multi room how much is it, how much is mini box
Re: Multi room
Depends on the price of the rest of your package and whether Sky will do you a deal or not. Check for offers on the MySky app or give them a call.
Re: Multi room
@Lovelocked
Multiroom is a Sky+ add-on. For Sky Q it's called Multiscreen.
You need to get a Multiscreen subscription and order a mini box or boxes.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+. It’s worth mentioning that UHD content can’t be viewed on a mini box.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
