Discussion topic: Multi room
This message was authored by: LouPLou1
Multi room
Hello,
One of the sky boxes isn't working in one of the room, I have multi room package.
I have tried calling to be placed on hold for long periods of time, I have struggled using your website, now using the app all of which very unhelpful.
can you help please?
Re: Multi room
@LouPLou1 wrote:
Hello,
Hi @LouPLou1
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
