Discussion topic: Multi room
This message was authored by: Agnes25
Multi room
Cost of multi room
Re: Multi room
@Agnes25 Best to call sky and ask as they may be able to offer you a deal
Re: Multi room
@Agnes25
Multiroom is a term for Sky+. For Sky Q it's Multiscreen.
Some useful information here…
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+. It’s worth mentioning that UHD content can’t be viewed on a mini box.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Re: Multi room
@Agnes25
List price is £15pcm, but frequently discounted.
Current offer appears to be £10pcm for customers new to Q.
