Discussion topic: Multi room
Message posted on 11 Nov 2024 01:02 PM
Multi room
My internet went last night. I manage get get back the WiFi but the multi rooms won't connect as main tv telling me no network connection
Message posted on 11 Nov 2024 01:09 PM - last edited: 11 Nov 2024 01:10 PM
Re: Multi room
Hi @Gina16
Once you get the main Q box connected, reboot the minis one at a time.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
If the minis still do not connect try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 11 Nov 2024 01:42 PM
Re: Multi room
Thank you. When I try connect the main sky q box it says unsuccessful connection so I can't get any further
