Discussion topic: Mimibox will not connect to q box
Message posted on 11 Nov 2024 12:03 PM
My mini box will not connect to the q box
Message posted on 11 Nov 2024 12:54 PM
Re: Mimibox will not connect to q box
Hi @Gary991
Reboot the mini as above.
