Discussion topic: Multi room signal issues
This message was authored by: NikkiA
I have Sky Q with 4 mini boxes. All the mini boxes except 1 work reasonably fine (just need resetting every so often) but one of the bedroom ones just seems to consistently be problematic. It is the furthest from the main box (in a bedroom) but we have a sky wifi booster outside the room. Despite the booster, this box constantly freezes and disconnects from the WiFi network.
Any ideas on what I should do next?
Re: Multi room signal issues
Hi @NikkiA
Assume it's a Sky Q WiFi booster you have?
If it is then reconnect the booster to the nearest Q device using WPS (other then the problem mini you are trying to connect)
Once it is connected carry out a Network reset on the problem  mini
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with nearest Q device (assume it's the Sky Q booster)
You will be asked to press the WPS button on the Booster  (not the mini as the Network reset will start the mini WPS automatically).
