Discussion topic: Multi room not working
Message posted on 04 Dec 2023 08:31 PM
Message posted on 04 Dec 2023 08:35 PM - last edited: 04 Dec 2023 08:38 PM
Re: Multi room not working
Hi @Ataur1 You are going to have to supply a few clues if you are looking for help. Error messages, what you are seeing on the screens etc. etc.
Message posted on 04 Dec 2023 08:41 PM
Hi @Ataur1
Reboot the mini as above.
