6
This discussion topic has been answered Discussion topic: Multi room keeps freezing
This message was authored by: Swn-y-Nant
My sky multiroom keeps freezing. It’s is connected to main q and wifi just freezes & we can’t watch It.
Re: Multi room keeps freezing
Hi @Swn-y-Nant
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Hi @Swn-y-Nant
Avatar for Swn-y-Nant
I have two boost boxes and have tried the above .. do appreciate your reply though. I think I need a new box for the room maybe?
Are the Boosters Sky Q WiFi boosters @Swn-y-Nant ?
If so you realise you need to connect these by WPS;  first to the Main Q box and then the mini.
Yes they are and have been connected for a while ... they are definitely working
This message was authored by: DJones1
No this doesn't work
This message was authored by: JJL
I have a similar issue. How do I make sure both boxes are correctly connected to the booster?
