This discussion topic has been answered Discussion topic: Multi room keeps freezing
Message posted on 06 Sep 2023 06:26 PM
My sky multiroom keeps freezing. It’s is connected to main q and wifi just freezes & we can’t watch It.
Message posted on 06 Sep 2023 07:18 PM
Hi @Swn-y-Nant
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Hi @Swn-y-Nant
Message posted on 06 Sep 2023 07:22 PM
Re: Multi room keeps freezing
I have two boost boxes and have tried the above .. do appreciate your reply though. I think I need a new box for the room maybe?
Message posted on 06 Sep 2023 07:30 PM
Are the Boosters Sky Q WiFi boosters @Swn-y-Nant ?
If so you realise you need to connect these by WPS; first to the Main Q box and then the mini.
Message posted on 06 Sep 2023 07:55 PM
Yes they are and have been connected for a while ... they are definitely working
Message posted on 21 Sep 2023 07:17 PM
No this doesn't work
Message posted on 29 Oct 2023 03:13 PM
I have a similar issue. How do I make sure both boxes are correctly connected to the booster?
