Discussion topic: Multi room box
Message posted on 28 Mar 2026 09:50 AM
Multi room box
Message posted on 28 Mar 2026 09:56 AM
Re: Multi room box
@Alanfreeman wrote:
Need to extra multi room box and is there a charge for this as I all ready have account with sky and have multi room already but need a extra box for another room
hi @Alanfreeman
Yes there is usually an admin charge for all subsequent minis, but there is no additional monthly charge
I have a feeling the charge is £50 but I could be wrong
You may already know but just in case you don't - you can use a maximum of 2 minis at the same time for SKY content - Satellite/Recordings- (only one if you have the non UHD box - Hardware version 32Cxxx) although you can have up to 4 on the account
You may be able to use more at the same time if the first ones in use are only being used for Streaming apps such as Netflix or Disney+
