Discussion topic: Multi room box
This message was authored by: Kyle3419
Multi room box
My multi room won't power up
Re: Multi room box
Hi @Kyle3419
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the Q box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing this work through the following link
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
