Discussion topic: Multi room box saying there is a connectivity problem
This message was authored by: the+Adorables
Multi room box saying there is a connectivity problem.
Re: Multi room box saying there is a connectivity problem
Hi @the+Adorables
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
