Discussion topic: Multi room.box not working
This message was authored by: Amandastang
Multi room box not working
Re: Multi room.box not working
@Amandastang  More information is needed as we can't start to provide help from the info currently provided.
@Amandastang Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Amandastang
Try a Network Reset on the mini.
You will be asked to press the WPS button on the main Q box (not on the mini as the Network reset will start the mini WPS automatically)
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
