Discussion topic: Mrs
Message posted on 09 Jan 2026 03:42 PM
Mrs
Replacement remote for sky q
Message posted on 09 Jan 2026 03:46 PM
Re: Mrs
@Blaengarwmarian
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken or faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 09 Jan 2026 04:21 PM
Re: Mrs
Also if you have apple device you actually down load app that is remote for sky q which you can use until get a proper replacement as well I not sure if there is the app in android phone App Store
Message posted on 09 Jan 2026 04:22 PM
Re: Mrs
Please read the last paragraph in my post immediately above yours.
Message posted on 10 Jan 2026 09:19 AM
Re: Mrs
Ok sorry I should have read properly
