Discussion topic: Mrs Teresa
Message posted on 17 Sep 2026 05:28 PM
Mrs Teresa
I have a new box and it had not added the apps
Message posted on 17 Sep 2026 05:57 PM
Re: Mrs Teresa
@Teresa1_ Have you tried rebooting your main Q box ie
I that doesn't work
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
