Discussion topic: Mrs Karen V
This message was authored by: Mummies
Mrs Karen V
I don't have any signal. It's been on and off for about 3 days. I have unplugged then plugged it back in a few times.
Re: Mrs Wells
Hi @Mummies   "No signal" or "No satellite signal". there is a big difference.
Re: Mrs Karen V
Re: Mrs Karen V
@Mummies
No signal and no satellite signal messages are different…
A ”no signal” message tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If it’s a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
▪️following adverse weather wait times for an engineer will probably be significantly longer
Re: Mrs Karen V
@Mummies
To prevent more duplication of replies your other thread has been removed (and its reply moved to this one).
